Seamlessly import-export models leveraging comprehensive file support. Select from STEP, IGES, X_T, STL, NX, and more to confidently deliver designs from any device, right alongside engineering.
Build strong collaborations across design and engineering communicating in the same 3D language, backed by a Siemens Parasolid kernel. You maintain the integrity of your workflow and design, confidently delivering manufacturing-ready models with built-in precision.
Directly edit geometry or design history on the fly without worrying about breaking your model, speeding up communication. Shapr3D’s clean, adaptive UI provides clear instructions on-screen, making navigation easier and letting you focus completely on your design.
Yes. Built upon Parasolid, all Shapr3D models are true solid models, and can be imported and exported in XT, STEP, STL, DWG, DXF, 3MF (import only) and OBJ (import only).
Yes, Shapr3D is compatible with SOLIDWORKS through SLDPRT and SLDASM for importing and exporting XT, Parasolid’s own file format that maintains all geometrical details.
Yes, Shapr3D is compatible with NX through a .PRT importer and a STEP / XT exporter.
Yes, Shapr3D can import STEP files on iPad, Windows, and macOS.
Yes, Shapr3D can import XT files on iPad, Windows, and macOS.
